when I use SPIGen connect to FRDM-KL25Z,why it always fails?I promise that I have configurated all related softwares and drive.The pictures as follollws:
3,783件の閲覧回数
1156114738
4 返答(返信)
3,518件の閲覧回数
Hui_Ma
Please download [SPIGEN version 7.1.2 PC interface software for Windows 7, 8, XP and Vista] from below link:
SPI Generator (SPIGen) Software|Freescale
There also provides USB to SPI Device Driver Installation Instructions - User Guide  about how to install the SPIGen driver to Windows system.
It needs to use KITUSBSPIEVME board (Evaluation Kit - USB-SPI interface), more detailed info, please check below link:
Evaluation Kit - USB-SPI interface, MC68HC908|Freescale
With KITUSBSPIEVME boards connects to USB cable, the [USB to SPI device] will be recognized as below:
Wish it helps.
best regards
Ma Hui
3,518件の閲覧回数
1156114738
When I connect to FRDM-KL25Z,Displays as follow:Q.png
It whether means I was failed?
3,518件の閲覧回数
Hui_Ma
I have tried to use FRDM-KL25Z board as USB to SPI device and it works.
Please check my connection for FRDM-KL25Z board and Windows device info:
Please re-program FRDM-KL25Z board with [UsbSpiDongleKL25Zv504] image and check again if it works or not.
best regards,
Ma Hui
3,518件の閲覧回数
Hui_Ma
For you are using FRDM-KL25Z board, I want to know which USB port you connected to PC?
Port 1 is KL25 USB port;
Port 2 is on board OpenSDA debugger port.
Wish it helps.
best regards
Ma Hui
