using fsl_dspi driver for simple spi
1,544件の閲覧回数
portal127
I'm new to NXP world. I have a FRDM-K28F board to evaluate the micro.
I have 2 standard SPI slave devices (with SCK, MISO, MOS and SS pins) and I want to configure the K28F as the master.
I use Keil, but the driver files for this device do not contain the fsl_spi driver. Only the fsl_dspi and fsl_qspi are present.
1. Why the standard driver is not included?
2. Can I use the device as a simple SPI master using any of this driver?
   - After googling I read that is possible, so:
   2a. What is the correct configuration? What should I watch out for?
   2b. There is an example of this use case?
Thanks in advance,
Antonio
タグ(2)
1,307件の閲覧回数
kerryzhou
Hi antonio,
    Thank you for the interest in NXP kinetis product, I would like to provide service for you.
  Now, answer you several questions:
Answer:   Actually, dspi is the SPI which you need, just in the K28 MCU, the SPI module name is DSPI.
  Don't worry, you can use that dspi examples.
Answer: Please refer to the official SDK code for K28, which can be downloaded from this link:
Welcome | MCUXpresso SDK Builder
Please choose the chip as MK28, then generate the code and download it.
After you download the code, you can find the dspi sample code in folder:
\FRDM-K28F\boards\frdmk28f\driver_examples\dspi
Please try it on your side, each example have the readme.txt help you to understand it.
Kerry
1,308件の閲覧回数
kerryzhou
Hi antonio,
Kerry
