rtcs HTTPSRV twrk60fa120m
685 次查看
andreeasafta
I'm working on a project whose purpose is to write something from the keyboard (using serial terminal Hterm), send that data on the RS232 serial and receive it and show it on a webserver.
I'm trying to modify the httpsrv code from rtcs folder in order to obtain on the webserver the data I'm sending from my serial terminal on the computer .
I managed to do this but I have a problem. When I write something like "abcdefg" it shows ok on the webserver but when I transmit "abc defg" (with a space between letters), it splits my string and shows on a line "abc" and on the next line "defg". I want to transmit it as a whole, including the space.
Do you have any idea how can I fix this issue?
Thanks a lot
623 次查看
DavidS
Hi Andreea,
Can you post your code example?
David
