output single character to Console terminal like TeraTerm
896件の閲覧回数
henrynguyen
I am using KDS 3.0 and KSDK 1.3x on K60 device.
I am able to output a line including \r\n on hyper terminal like TeraTerm using ConsoleIO from PEx through UART.
however, if the output is a single character without \r\n, the Teraterm terminal is not able to display this single character.  It has to wait until a \r\n to be able to display on TeraTerm.
i looked at the generated ConsoleIO code and it seems that the uart just output any character it receives out to output buffer.  I check Teraterm but could not find any setting that can impact this.
Has anyone run into this trouble before?
Henry
834件の閲覧回数
henrynguyen
Hello again,
i would like to clarify one thing is that if i use Term from PEx, i can send single character or line of characters with \r\n and TeraTerm does not have any issue.
Henry
