I am trying to get a MKL03Z32xxx4 running on a custom board. Processor expert generated much code for me but when I test using jlink for debugging, I dont see main(or anything else in my reset vector).
I'm new to processor expert but from the guide i thought that processor expert was suppose to generate the vector and copy it to ram by default. I this is not the case how do i get my code into the reset vector?
Cedrick
Hi Cedrick Kukela,
I find your JLINK driver is very low, please download the new JLINK driver and try again:
SEGGER - The Embedded Experts - Download
Besides, check these points:
1.Did you try another IDE? Eg, MDK, IAR, and use the KSDK sample code, whether it is still have problem.
2. Please check your hareware, test the NMI pin, whether it is high. did you add 4.7K to 10K external resistor?
3. Send me your test project, I need to test it on myside. It seems that your problem was not caused by the software. We need to find the root problem
Waiting for your reply!
Jingjing
Here is a copy of my console log. I think the errors are the cause of this mess.
SEGGER J-Link GDB Server V4.80c Command Line Version
JLinkARM.dll V4.80c (DLL compiled Jan 21 2014 20:01:42)
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
------J-Link related settings------
J-Link script: none
Target interface: SWD
Host interface: USB
Target endian: little
Target interface speed: 30kHz
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled Mar 29 2016 18:46:37
Hardware: V9.30
S/N: 59303487
Feature(s): GDB
Checking target voltage...
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x00000000 (Data = 0xFFFFFFFF)
Target interface speed set to 30 kHz
Resetting target
Halting target CPU...
...Target halted (PC = 0x1C0000C0)
R0 = 00000000, R1 = 1C001839, R2 = 00000000, R3 = 00008000
R4 = 00000000, R5 = 1C001CB8, R6 = 00000000, R7 = 00000000
R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
R12= 00000000, R13= 20000218, MSP= 20000218, PSP= 0B7E67F4
R14(LR) = 1C00071F, R15(PC) = 1C0000C0
XPSR 61000000, APSR 60000000, EPSR 01000000, IPSR 00000000
CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
Select auto target interface speed (2000 kHz)
Flash breakpoints enabled
Semi-hosting enabled (VectorAddr = 0x08)
Wrong client mask. Semihosting I/O not changed.
SWO disabled succesfully.
ERROR: Could not detect CPU clock speed. Download of test code into RAM failed.
Failed to restore original RAM content after CPU clock frequency detection!
Failed to enable SWO. Could not measure target CPU frequency.
Downloading 192 bytes @ address 0x00000000 - Verify failed
Downloading 16 bytes @ address 0x00000400 - Verify failed
Downloading 16064 bytes @ address 0x00000410 - Verify failed
Downloading 2228 bytes @ address 0x000042D0 - Verify failed
Downloading 8 bytes @ address 0x00004B84 - Verify failed
Downloading 4 bytes @ address 0x00004B8C - Verify failed
Downloading 4 bytes @ address 0x00004B90 - Verify failed
Downloading 108 bytes @ address 0x00004B94 - Verify failed
Writing register (PC = 0x000004e8)
Read 4 bytes @ address 0x000004E8 (Data = 0xFFFFFFFF)
Read 2 bytes @ address 0x00001C4C (Data = 0xFFFF)
Resetting target
Read 4 bytes @ address 0x1C0000C0 (Data = 0x490D480C)
Read 4 bytes @ address 0x1C00071E (Data = 0xD0F52800)
I am still struggling with this and am just looking for sources of more information. I have my interrupts to fun form internal Flash as well as my code. I think there is something wrong with my linker config or vector table config. Could some out post a working linker config for this processor? I am also looking in to how to set the vector table register. Any info would be appreciated.
Cedrick
Hi Cedrich Kukela,
The vector table already in the startup_MKL03Z4.s.
About the working linker config, you can refer to the KL03 KSDK1.3.0, there has a lot of sample code for your reference, all these sample code is working ok.
Please download the sample code from this link:
Software Development Kit for Kinetis MCUs|NXP
You can refer to the gpio code:C:\Freescale\KSDK_1.3.0\examples\frdmkl03z\driver_examples\gpio\kds
Wish it helps you!
If you still have question, please let me know!
Jingjing
Yes jlink commonader can see the processor
when i think there is a problem with the binary that is created. when i look at the dis assembly, some sections seem to be left undefined(even for the demo apps).
my isr shows much of the same.
Any advice?
Hi Cedrick ,
What the IDE you are using with PE? KDS?
I use the KDS create a Processor expert with KSDK1.3.0 for your referece.
You can find the main calling in the startup_MKKL03Z.s, in the startup file, there has a reset handler which calls the main function, just like the following picture:
The project is in the attachment.
Wish it helps you!
If you still have question, please contact me!
Jingjing
Thank you for your reply,
I do have all the of the start up files and my .S file does have the reset handler. The problem is when i run my application and try to debug it I seem to have nothing in 0x00000000 and 0x00000004. These should be the initial stack register value and pc. Because they are missing my fails to initialize properly. Yes I am using kds with pe. I am all so using jlink on my custom board to read see what is going on.
any suggestions would be welcome. I think i am making a mistake somewhere in my linker settings. I am pretty sure processor expert generates they initial isr.
Thank you
Cedrick
Hi Cedrick Kukela,
Do you mean when you run my project directly, and you also can't enter in main? This project just a empty project, and it is working ok on my FRDM-KL03 board.
Could you give me a screenshot where your code stopping?
I wondering whether your hardware can download the code, please give me some problem picture from your side.
Besides, please use the JLINK Commander check your board, whether it can find the ARM Cortex M0+ core.
Jingjing
When i look at my generated code folder I have the start up files defined. They also have entries in my map file. For what ever reason though I i end up with nothing in my isr. my reset vector does not call the reset handler. Does any one know how to get processor expert to load this. I have included my ld file and map.
Thank you
