Any working PE demos we can experiment with?
Solved! Go to Solution.
I believe that the best approach is to use the examples found in the installation folder of CW 10.3
C:\Freescale\CW MCU v10.3\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-KL25Z48M
I hope this helps,
Alejandro
Basically something to compliment AN4631 but it doesn't provide a project.
Steven, is this suggestion helpful?
Please let us know! :smileywink:
I have made a big commitment to using PE, so starting in a different path isn't where I want to go. So still hoping for a PE example that works. I will be passing this along to my customer after I try it myself.
hi
In these examples you have a low power UART with DMA example
http://cache.freescale.com/files/32bit/software/KL25_SC.exe?fpsp=1&WT_TYPE=BSDL&WT_VENDOR=FREESCALE...
This is not PE but will be a good starting point to use this for ADC with DMA.
