kinetis ke04 NMI pin
jun1
Thank you for your help.
The NMI pin is open because it is unused. If the default settings after power-on reset are used, will NMI be applied without pulling up externally?
Also, if NMI is not used, are there any registers that should be set in relation to NMI?
Thank you.
jun.
