iseled SPI protocol
iseled SPI protocol
1,405 次查看
toxuandung
Dear NXP,
I need to build the application using MK22FN512 to control the iseled via INLC10AQ by SPI protocol.
But there are no any document about the address to send the command for example digLED_Init_Strip.
Is that possible to give me that kind of document .
Thanks you so much !
1,390 次查看
RaRo
Hello @toxuandung,
Unfortunately, we do not have a document to control ISELED INLC10AQ via SPI for the MK22FN512.
Nonetheless, might be useful to take a look to the following documentation for your application:
Hope any of the information may work for you.
Regards, Raul.
1,391 次查看
RaRo
Hello @toxuandung,
Regards, Raul.
