Hi, I am new in this of the kinetis microcontroller, and i have the FRDM KL25Z but when i wanna debbug, codewarrior shows a error alert....Can somebody help me please??...
解決済! 解決策の投稿を見る。
Hi Jose,
have you switched to the SDA debug application? It looks like you are running the wrong firmware for debugging.
See
The Freescale OpenSDA Trap: “No Device Available”, or something like that…. | MCU on Eclipse
By default the firmware running in the OpenSDA device is the MSD, you have to program the debug application into OpenSDA.
Follow the OpenSDA User Guide.
http://cache.freescale.com/files/32bit/doc/user_guide/OPENSDAUG.pdf?fpsp=1&WT_TYPE=Users Guides&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
Then CW will detect your debugger device.
Luis
Hi Jose,
See
Thanks bro, already i can debbug my board....
HI Jose,
Which device are you using for debugging? Multilink, Cyclone pro, Jtag, or OSBDM? you will need the drivers for whichever debugging tool you are using.
Hi, i believe that is the OPEN SDA, and i did install the drivers of the FRDM. The KL25 FRDM don't need a BDM..
