how to give OSCERCLK into timer input in KL26Z
1,209 次查看
arthshah
hello kerryzhou
i want to know about OSCERCLK clock.
i know how to use this clock to timer input but i want to know about how can i achieve about 24MHz clock using OSCERCLK into timer input?
Thanks And BestRegards,
Arth Shah
1,091 次查看
jorge_a_vazquez
Hi Arth Shah
I would like to recommend you check chapter 5 of the reference manual:
https://www.nxp.com/docs/en/reference-manual/KL26P121M48SF4RM.pdf#page=131
Here you can find a full description of the clock distribution for this MCU. As you can see OSCERCLK is the System oscillator output sourced directly from OSCCLK.
I also recommend you check our clock tool that comes with SDK software:
Welcome | MCUXpresso SDK Builder
TIC
