how to burn a program using kinetis design studio
450 次查看
sameerarvikar
1>how to burn a release mode file using kinetis design studio?In user guide of kinetis sdk everything given is about debugging
2>I want to program filename.srec on the kinetis k70 ,can i do it and how ??
I am using Kinetis TWR-K70F120M board
332 次查看
mjbcswitzerland
Specialist V
To directly program binary or SREC files in KDS use the Flash Utility (the icon with a bolt of lightening).
This requires you to configure a debug target (similar to when debugging) for your debugger and the Kinetis device, select the file to be loaded and then you can erase or program flash.
Mark
