how to add support for kw41z in kinetis design studio?
1,899 次查看
mangramarco
Hello, i installed kinetis design studio and i'm trying to create new projects for kw41z mcu. Unfortunately when i create a new kinetis project and i try to select processor name i read many mcu name but there is not kw41z.
How can i add support in kinetis design studio for this micro?
Best regards and thank you
标签 (1)
标记 (2)
5 回复数
1,724 次查看
derekbarnes
Hi Estephania,
I am also having this issue and I just need the MCU support in KDS.
Thanks.
1,724 次查看
estephania_mart
The connectivity software it's not supported in the Kinetis Design Studio, you will need to use either MCUXpresso or  IAR?
Estephania
1,724 次查看
derekbarnes
Estephania I did not ask about the connectivity software. All I want to do is create a new project with a KW41Z processor. I had this working on my old computer but when I installed everything on my new computer the only support is for a KW40Z.
1,724 次查看
estephania_mart
You can download the SDK for the KW41Z in this link, you will need to look for the Kinetis KW41Z Connectivity Software, nonetheless, that connectivity stack it's no longer supported.
Estephania
1,724 次查看
estephania_mart
Are you looking for the connectivity software support in KDS or just the MCU support?
Estephania
