expansion boards for a kinetis 64 board
1,335 次查看
randyseedle
Are there any expansion boards out there that use the kinetis specific I/O pins ?
标签 (1)
3 回复数
1,055 次查看
randyseedle
Hmmm, so is a good document describing the inner row of pins ?
1,055 次查看
BlackNight
AFIK there is no dedicated document for this, and now standard. Every board has different pins on the inner rows. The best document for it is is the schematics PDF.
1,055 次查看
BlackNight
not sure what you mean with Kinetis specific I/O pins? Or do you mean the inner rows? They make sense if you develop your own board. I'm not aware of any commercial boards which use them. The outer 'standard' rows can be used with all the 'Arduino' shields as long they are designed to work with 3.3V logic levels.
I hope this helps,
Erich
