eDMA channel idle
eDMA channel idle
1,118 次查看
martindusek
Contributor V
how to check whether a dma channel is free to execute new DMA request? I thought about using ACTIVE and DONE bits of CSR register, but it seems they are not suitable for that.
Checking DONE == 1 works only when there was previous DMA transaction (it doesn't work if the DMA channel hasn't been used yet).
And ACTIVE is set to 0 on minor loop completition. I want something that tells me all major loops (whole tranaction) has been completed.
Thanks for help.
1,020 次查看
mjbcswitzerland
Specialist V
You could do a single dummy transfer during system initialisation in order to prepare the DONE bit and then use it as flag during subsequent operations.
Mark
1,020 次查看
martindusek
Contributor V
Hi Mark,
thanks. I'll do it If this is the only possibility...
