In the cw10.6, Only sci and bdm can are avialible for the components of freemaster? I want know that does the keaz128 can use the freemaster though the can channle?
thans!
Solved! Go to Solution.
Yes, it seems Freemaster component in PE in CW and KDS only support SCI and BDM. You have to port Freemaster CAN driver by yourself. There is a DOC in community make the step very clear. You can refer to it.
https://community.nxp.com/docs/DOC-341890
Jing
Jing
Hi Jing Pan,Thank you for your reply!
