clk out to drive ic
clk out to drive ic
1,075 次查看
bilgekaanugur
I need a clock source ( 8-16 mhz ) to  feed ic .  what is the suitable method in ke04 family to generate this ?
988 次查看
Robin_Shen
1. Using PTH2 output bus clock. You can also enable bus clock output via an optional prescaler.
2. Using "Output Compare mode" of FTM module. It can be configured to Toggle mode.
Robin
989 次查看
Robin_Shen
Robin
988 次查看
bilgekaanugur
thank you Robin for your prompt reply.
regards
