bug? - from khci_dev.c : usb_dci_khci_get_xd()
1,105件の閲覧回数
csjc
when there are no entries, the return path calls OS_Mutex_unlock instead of OS_Unlock() used in the success return path.
    /* This function can be called from any context, and it needs mutual
       exclusion with itself.*/
    OS_Lock();
    /* Get a transfer descriptor for the specified endpoint
     ** and direction
    if (!usb_dev_ptr->xd_entries)
        OS_Mutex_unlock(usb_dev_ptr->mutex);
        return USBERR_DEVICE_BUSY;
  • USB
858件の閲覧回数
Hui_Ma
Hi Chris,
It is a known issue, the correct code should be:
        OS_Unlock();
The fixed code will be released at this December.
Thank you.
Wish it helps.
best regards
Ma Hui
3 返答(返信)
858件の閲覧回数
csjc
again this is from the ksdk usb 1.0.0 GA release code
859件の閲覧回数
Hui_Ma
Hi Chris,
        OS_Unlock();
Thank you.
Wish it helps.
best regards
Ma Hui
858件の閲覧回数
csjc
It wasn't known to me.  Is there a public list?
This is the type of bug that can cause a significant amount of wasted debug time.  Please impress on the appropriate team that the errta needs be kept up to date.
