X-KW45-EVK power measurement
MSM1
I am measuring power consumption on X-KW45-EVK following the same recommendation as AN13230 application note section "5.2 Measuring current consumption"  trying to measure ireg.
I have followed the same recommendation except that i am using only a source meter:
vdd on JP5-3 at 3.3v
gnd on TP18
usb connected on j14
jp10 on buck
the consumption seems strange to me like a noise , i have attached a figure.
Note : i am using lowpower_peripheral application. the application is running fine , i observe advertising packets.
am i missing something ?
Kind Regards,
MSM.
MSM1
The measurement made was a setup issue and it is solved now.
Thanks for the support.
MSM.
Ricardo_Zamora
Could you please share a photo of your setup?
Also, what is the scenario you are comparing with? (Which of the 5.2.2 Measurements and results)
Ricardo
