Can anyone knows how does low level files or drivers of LIN stack package from NXP work?
Will they count the 13 bits of synch break signal and thus detect the header and followed by a sync byte (0x55) ?
The KEA product UART module supports the LIN bus, which LIN master can send 13bit break, LIN slave can detect that 13bit break.
The actual test LIN bus with that 13bit sync break (baud rate: 10.4Kbps):
Thank you for the attention.
best regards,
Mike
