I am using the MK10DX256VLH7, and I want to use the open drain output functionality. When I check the data sheet, it tells me about the ODE bit in the PORTx_PCRn configuration register, and says in the features overview:
"Individual open drain field supporting enable and disable of the individual open drain output on selected pins"
Unfortunately I can nowhere find a list telling me which pins support open drain output. Does this exist anywhere?
( I could test every pin by checking whether I can change ODE, but I would rather not go that route)
