I m planning to make a project with inbuilt Accelerometer on the Free Scale KL25Z board so i wanted to know which pins are connected with with of output bus is connected with accelerometer .
Solved! Go to Solution.
Hi aman,
You can refer the Schematics of FRDM-KL25Z board.
You can find the Schematics of FRDM-KL25Z (RevE) in FRDM-KL25Z_SCH_REV_E.
See below:
Also you can find the Schematics of RevD FRDM-KL25Z_SCH_REV_D
Hope that help
Best Regards
Robin
Aman,
You might also find useful my example code for the MMA8451Q accelerometer and FRDM-KL25Z platform.
Tomas
Hi aman,
See below:
Hope that help
Best Regards
Robin
I recommend to have a look at the schematics: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=FRDM-KL25Z
(check with revision of board you have, either E or D)
Otherwise have a look here: http://mcuoneclipse.com/2012/09/21/tutorial-accelerating-the-kl25z-freedom-board/
