Where do I get new versions of MKL25Z4.h?
已解决
跳至解决方案
2,756 次查看
markosiponen
I'm testing some code on the FRDM-KL25Z board. And I have tried the processor expert and then the Keil µVision. I noticed that Keil has an old MKL25Z4.h file.
The processor expert generates an IO_Map.h file that really is the MKL25Z4.h file. But the file that PE generates is a newer version than in Keil.
Where do I get new versions of these files for Kinetis MCUs (exept getting them from PE)?
1 解答
1,839 次查看
chris_brown
Hi Markosiponen,
You could get them from the KL25_SC repository available at www.freescale.com/frdm-kl25z/.
~Chris
在原帖中查看解决方案
4 回复数
1,839 次查看
JimDon
Senior Contributor III
It is in the Codewarrior directories.
To find it, generate a non PE projects, the open it in the IDE and see where it is.
1,839 次查看
markosiponen
But what if I don't have Codewarrior?
1,840 次查看
chris_brown
Hi Markosiponen,
~Chris
1,839 次查看
markosiponen
Where can I find similar files for other freescale MCUs?
