I'm testing some code on the FRDM-KL25Z board. And I have tried the processor expert and then the Keil µVision. I noticed that Keil has an old MKL25Z4.h file.
The processor expert generates an IO_Map.h file that really is the MKL25Z4.h file. But the file that PE generates is a newer version than in Keil.
Where do I get new versions of these files for Kinetis MCUs (exept getting them from PE)?
已解决! 转到解答。
Hi Markosiponen,
You could get them from the KL25_SC repository available at www.freescale.com/frdm-kl25z/.
~Chris
Hi Markosiponen,
~Chris
