Where can I find a bsdl file for a MK60DN512ZVMD10?
1,662 次查看
chrislaudenslag
Looking for a bsdl file for testing a
MK60DN512ZVMD10.
5 回复数
1,410 次查看
ivadorazinova
Hi Chris,
please see attached file.
Let me know if this works you.
Iva
1,410 次查看
chrislaudenslag
Iva:
I tried using the k60_100mhz_144map_13x13_xm33z_xn30d.bsdl file for
JTAG testing my MK60DN512ZVMD10 device, but I get an IDCODE error.
The
measured IDCODE is 01111011000101001010000000011101 (0x7B14A01D).
The
Expected IDCODE is  00111011000101001010000000011101 (0x3B14A01D) - this comes
from the BSDL file.  Is there a newer bsdl file for my device than what you
shared with me, since the
first nibble of the IDCODE is the version
Chris
1,410 次查看
ivadorazinova
Hi Chris,
I requested for the file.
I will send it to you as soon as possible.
Thank you for your patience.
Iva
1,410 次查看
maheshwarreddy
Thank you for the reply , If possible please send the code in the keil ,
thanking you
On Thu, Jun 23, 2016 at 5:02 PM, ivadorazinova <
1,410 次查看
ivadorazinova
Hi maheshwar,
Please, check bsdl file from attached folder.
I hope this helps.
Iva
