Where can I find Kinetis complimentary bootloader?
2,151 次查看
Niall
Section 6.4 of the Kinetis K60 Product Brief states that complimentary bootloaders for USB, Ethernet, RF, serial are provided as additional software stacks. Have these bootloaders beens released for Kinetis? If they have, does anyone know where they can they be located?
1,506 次查看
dhaval_v_shah
There are few at freescale.com>products>kinetis>K60>Documentation>Application Notes
Dhaval
1,507 次查看
dhaval_v_shah
Dhaval
1,506 次查看
Niall
Thanks Dhaval.
The USB and ethernet bootloader application notes were released last week. I can't find any reference to the serial or rf bootloaders. I presume they have not been released yet.
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
