Where can I find Examples for MKW41Z512xxx4
946 次查看
andrewgatrost
I am looking for an example using the uart with FreeRTOS.  I was told that I can build an SDK with adding Amazon FreeRTOS for middle ware to get these examples.  I could not find "Amazon FreeRTOS" anywhere on the SDK build page.  Any help would be appreciated
标记 (3)
1 回复
844 次查看
mario_castaneda
Hi Andrew,
When you open the Select Software Components, you will find the option in operative Systems FreeRTOS.
Please look at the next exxample in your SDK
\SDK_SDK_2.2_FRDM-KW41Z\boards\frdmkw41z\rtos_examples\freertos_lpuart
Mario
