What register should be configured before useage the FPU in MK60FX512VLQ15?
2,529 次查看
朱葛峻
What register should be configured before useage the FPU in MK60FX512VLQ15? Thanks.
2,378 次查看
mjbcswitzerland
Specialist V
Access to the FPU is enabled with CPACR |= (0xf << 20);
Mark
6 回复数
2,379 次查看
mjbcswitzerland
Specialist V
Mark
2,378 次查看
朱葛峻
Sorry, I don't find this register named CPACR in header file.Could you tell me in detail ?
2,378 次查看
Kan_Li
Hi 朱葛峻,
I think Mark mean the following register, you may refer to http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf for more details.
Kan
2,378 次查看
朱葛峻
谢啦我先看看
2,378 次查看
Wlodek_D_
Senior Contributor II
Dear 葛峻 朱,
Thank you for your post, however please consider moving it to the right community place (e.g. Kinetis Microcontrollers ) for better visibility.
For details please see general advice https://community.freescale.com/docs/DOC-99909
Thank you for using Freescale Community.
Wlodek_D.
2,378 次查看
朱葛峻
谢啦。
