What is where on MIMXRT1060-EVK?
hgiese
does a document exist where one can see _where_ all the jumpers, resistores and switches are located? Hopefully as PDF - then I could enlarge it as much as I need, print it out and tape it on the wall. You see, I'm not a young man anymore and my vision is rather bad.
Thank you
Helmut
jingpan
Hi @hgiese ,
Please refer to RT1060-EVK user manual. The jumper table is at section 1.8 and 1.9.
file:///C:/Users/nxf32199/Downloads/MIMXRT1060EVKBUM.pdf
Jing
hgiese
Hi Jing,
many thanks for this tip. I found the file MIMXRT1060EVKBUM.pdf but there is a small problem: It does not show the board I have. I got mine last summer. It shows 2 stickers
- 701-31357 Rev. A and
- SCH-31367 Rev. A2
whereas the said document says in 'Revision History': Rev. 0, Date: 7.Jan. 2022, 'Initial public release', the Arduino connectors are labeled J16, J33, J17 and J22 while on my board they are labeled J22 - J25, etc.
So I guess this document describes a revision whis is different from mine, and since it was published only in January this year as 'Initial public release' I'm afraid a similar document does not exist for the revision I have.
Nevertheless many thanks for your help, this document is still helpful
Helmut
mjbcswitzerland
Specialist V
Hi Helmut
I have printed some Gerber file layers in PDF for you - see whether they are useful.
Mark
See
https://www.utasker.com/iMX/developers.html
for various i.MX RT 1060 resources to simplify developments
hgiese
Spoiler
Hi Mark,
many thanks for your help. The PDFs help a bit - if they were searchable (for text) they would be perfect.
Still, thank you for your help.
Helmut
