What is the best way to generate a 60Hz SW clock using the K70? The clock will be used to drive some external logic.
916 次查看
prahsman
SW is for square wave - not software
1 回复
792 次查看
santiago_gonzal
Hello Ken,
The FlexTimer module has a lot of configurations and options to be used as a PWM generation, have a look at the Reference Manual of K70.
Santiago
