What is the Read/Write Cycle (Endurance) if we use FLEXNVM as D-Flash in KW38
Vishva
What is the maximum read/write cycle if we use FLEXNVM as D-Flash in KW38.
i.e. How many times can we erase and reprogram.
Kindly check and let me know.
Thanks in advance.
vicentegomez
please check the table 28 and 29 on the data sheet
https://www.nxp.com/docs/en/data-sheet/MKW39A512.pdf
I hope this will help youRegards
