What is different between JTAG/SWD interface in FRDM-K20D50M?
2,792 次查看
kai_liu
Senior Contributor I
I found that there are two different debugger interfaces in FRDM-K20D50M. The OpenSDA and target micros are all K20D50M family. Why does FSL decide to use JTAG for OpenSDA, and SWD for target micro? Any special reason?
1,500 次查看
Paul_Tian
Hi, Liu Kai
Because Cortex-M0+ does not support JTAG debug, so Kinetis L series use SWD debug interface. But if you have J-Link on your hand, you can use top half interface for SWD debug. Thanks.
Hope my reply can help you.
Best Regards
Paul
1,500 次查看
jeremyzhou
Hi Kai,
In fact, I also don't know the exactly reason and I've nout found the special reason for these desgins in any documents.
However I think it's not hard to speculate. L series Kinetis only support SWD which make it can't support other debug interfaces except SWD.
K series Kinetis can both support JTAG and SWD, so choose JTAG is reasonable.
Wish can help.
Ping
