Solved! Go to Solution.
Hi, Mark,
Pls refer to the section 3.6.1.2 16-bit ADC electrical characteristics in data sheet of K65, the fADCK frequency ranges from 1.0MHz to 24MHz for the mode less than or equal to 13 bits mode, or ranges from 2.0MHz to 12Mhz for 16 bits mode.
Regarding the optimum fADCK, we have provided the curve of Typical ADC 16-bit Single-Ended ENOB vs ADC Clock, from the curve, you can see that the ADC16 can give optimum accuacy when the fADCK ranges from 2~6MHz.
I copy the curvbe here:
Hope it can help you
Xiangjun rong
Hi, Mark,
Xiangjun rong
