Once you select the Wdog component, you must go to Events tab and select "generate code" on OnWatchDog option in order to create the ISR entry that will be called once watchdog timeout occurs:
Then Save changes, generate code and ISR should appear on event.c file:
** Event : WDog1_OnWatchDog (module Events)
** Component : WDog1 [WatchDog_LDD]
** @brief
** Called if watchdog time-out occurs. WatchDog must support
** this feature and must be enabled.
** @param
** UserDataPtr - Pointer to the user or
** RTOS specific data. The pointer passed as
** the parameter of Init method.
void WDog1_OnWatchDog(LDD_TUserData *UserDataPtr)
/* Write your code here ... */
Hope this helps!
Isaac
