Hi All,
My application is configured to wake up on external event on GPO(i.e PTC11). Proccessor is not waking up when i enter sleep
_lpm_set_operation_mode (LPM_OPERATION_MODE_SLEEP);. where as i am able to wakeup when enter LPM(low power mode) using
_lpm_set_operation_mode (LPM_OPERATION_MODE_WAIT);. Could anyone guide to reslove the issue.
savinay
Hi Savinay,
Are you trying to run the code with "lowpower" demo under MQX folder? Which MQX version you use? Are you running this with Freescale tower board or with your own board? If you are running with your own board, did you port the BSP?
If you have written your own low power entry code, then please share your code.
Hao
Hi Hao,
We are using our own board. BSP is ported to this board. We are using lpm api provided by BSP to enter low power mode.
savinay
