USB3.0 and K65
USB3.0 and K65
2,284 次查看
goranigic
I am using K65, external SDRAM, and SD card. Is it possible to connect FT600 to that configuration?
I know that FT600 doesn't have FLEX-BUS. I am also using K65 USB 2.0 port.
This is the last moment customer request to add USB3.0 support (as second USB port).
g
p.s.
I have seen the discussion:
usb3.0 with K80
2,063 次查看
Hui_Ma
K65 product has the Flexbus module.
The chapter 34 of K65 reference manual provides the detailed info.
There is an application note about multiplexing pins between SDRAM and Flexbus on K65.
For more detailed info, please check here.
Wish it helps
Ma Hui
2,063 次查看
goranigic
K65 doesn't have FLEXBUS
FT600 uses 16b FIFO
g
2,064 次查看
Hui_Ma
Wish it helps
Ma Hui
2,063 次查看
goranigic
It doesn't have flex memory, but it has the flex bus.
I appreciate your response
g
