USB, ETHERNET PILHA K60
1,323 次查看
samueldionisiod
Pessoal, bom dia.
Gostaria de saber se é possível eu implementar Ethernet, USB  no K60 sem utilizar o MQX.
Será que a freescale já fornece?
Com Ethernet vou precisar implementar SNMP e HTTP.
Obrigado.
Samuel
标记 (5)
1,151 次查看
apanecatl
Senior Contributor II
It is possible to implement Ethernet on a K60 using only baremetal code however you might find it quite time consuming developing the code, unfortunately we don't have any baremetal code example for that.
1,152 次查看
apanecatl
