UART DATA TRANSFER PROBLEM
5,691 次查看
marceli1
I am using USB -TTL-5V cable to work with MKE02Z64VLC chip. Mine receiver on interrupt only receiving one character. Should I toggle CTS pin to receive rest of characters?
void AS1_OnRxCharExt(AS1_TComData Chr)
 /* Write your code here ... */
 word Received;
 //byte err = 0;
 (void) AS1_RecvBlock((byte*) &rx_message.RxBuffer, RX_DATA_BUFF_SIZE, &Received);
Due to different received data length I need to detect last character '\0'.
标记 (1)
1,548 次查看
marceli1
Problem finally was solved, as:  while using only Internal oscillator it can not be adjusted for standard baud rate. Just use whatever it gets, i.e. 58308.
New code looks like this see attachment.
