Typos in SDK 2.4.0
Typos in SDK 2.4.0
4,923 次查看
Keith4DSmith
To whom ever it may concern, attached is a list of many of the typos I have found in comments the USB middleware of the SDK 2.4.0 source. This is not an exhaustive list.
标记 (2)
7 回复数
4,620 次查看
danielchen
Hi Keith Smith
Thank you very much for your feedback, appreciated!
 I forwarded your input to the usb team, hopefully they can improve it in next release.
Have a nice day!
4,620 次查看
Keith4DSmith
Attached are additional errors found in the SDK 2.4.0. These are mostly around Doxygen syntax errors.
I received many warning '... not documented' from various SDK files.
4,620 次查看
danielchen
Thank you very much. will be fixed in SDK2.5.0
4,620 次查看
Keith4DSmith
I missed a few more typos.
4,620 次查看
danielchen
Thank you again.
4,620 次查看
Keith4DSmith
Daniel - Here's an additional list of typos in comments from SDK 2.4. [Can't seem to find how to attach a document to a reply.]
27Jun18
Filename
Line Number
Typo
fsl_edma.c
129, 143
periphral -> peripheral
fsl_edma.c
348
likned -> linked
fsl_edma.c
549
attibute -> attribute
fsl_edma.c
717
blcok -> block
fsl_edma.c
737
notfinished -> not finished
fsl_edma.c
870, 873
blcoks -> blocks
fsl_edma.h
242
stcd -> tcd
fsl_edma.h
258 (twice), 261
paramter -> parameter
fsl_edma.h
261
regsiter -> register
fsl_edma.h
802
preapre -> prepare
fsl_ftm.c
62
Syncronization -> Synchronization
fsl_ftfx_cache.c
457, 531
instaruction - > instruction
457, 531
cahce -> cache
fsl_ftfx_controller.c
542, 738
paramters -> parameters
547, 747
seperate -> separate
1378, 1392
gived -> given
fsl_ftfx_flash.c
503
inidicator -> indicator
fsl_ftfx_flash.h
398
programed -> programmed
517
uninitialzed -> uninitialized
fsl_ftxflexnvm.h
365
fsl_gpio.h
175, 195, 213, 238, 265, 295, 312, 365, 428, 448, 468, 488, 515, 544, 561
superceded -> superseded
fsl_lpuart.c
81, 93
addresss -> address
445
shoft -> shift
857
transmiter -> transmitter
fsl_lpuart.h
120
conuting -> counting
fsl_pit.h
129
onfiguration -> configuration
fsl_smc.c
159
Noraml -> Normal
fsl_uart.c
95
addresss -> address
316, 739
fsl_uart.h
95
165
paritye -> parity
fsl_debug_console_conf.h
49, 61
ultilization -> utilization
62
overwrited -> overwritten
fsl_log.c
158
calucate -> calculate
223, 225, 226, 234
avaliable -> available
365, 432
recieve -> receive
497
losed -> lost
fsl_log.h
86, 98, 123
99, 108
recieved -> received
fsl_str.c
935
convernsion -> conversion
fsl_str.h
67
callbck -> callback
fsl_clock.c
231
regardness -> regardless
779
fequency -> frequency
fsl_clock.h
72
contol -> control
967
internall -> internal
968, 982
confuration -> configuration
1395, 1413
souce -> source
1466, 1478, 1481
sytem -> system
fsl_common.c
42
adress -> address
fsl_common.h
494
convinience -> convenience
MK22F1212_features.h
57
acces -> access
80
remamed -> renamed
4,620 次查看
danielchen
Hi Keith Smith
Thanks again.   Please use advanced editor attaching your document in a reply
