The problem of collecting the internal temperature of K66 ADC.
jetli
Recently,My Project(Kinetis K66) need using the ADC capture pin voltage and internal CPU temperature.Project ADC acquisition sequence is the first collection of pin voltage, and then capture the temperature, reciprocating cycle.When I do not pick any voltage source on the pin , the acquisition temperature is normal(16bit adc value 6545).But if I pick voltage source on the pin , the acquisition is mistake(16bit adc value 16254).I don't why? Somebody who can help me?
Tags (2)
Jonathan_Iglesias
Dear jet li,
Can you give me more information or send me your project to have a better understanding of the problem.
Best regards.
Jonathan.
jetli
Dear Jonathan lglesias,
      After your company's technical staff to help, I found reason is ADC input frequency is too high, resulting in interference between the channels, and now has been working very well, thank you!
Best regards.
jet li;
