TWRK20D72M help - "Failed to resume target process., There was an error parsing the memory configuration file"
Search instead for
lander
I have been trying to find a solution for this problem all day.  I am running codewarriors v10.2 on eclipse and I am trying to run the "hello world" sample code with the tower.
I looked around the memory configuration files but I'm a little lost on which one to choose or if that is even the thing I need to change.
Thank you,
Lander
Tags (2)
adriansc
Try with a another COM port in your computer, also uninstall and install again the drivers.
Maybe you will need to downgrade the firmware of your TWR-K20, for that you need to use the P&E Firmware update and recovery utility. With recovery utility you can select the firmware file to flash your board.
You can find it here: P&E Microcomputer Systems
Hope this helps.
