TWR_SER2 board weird behavior
585 次查看
henrynguyen
i have TWR_SER2 board and the attached schematic for it.
I tested the ULPI_CLK output on transceiver itself by shunting the JP24 to get 3.3v from USB supply.
I checked the USB3300 reset signal and it is low (active high).
I check the ULPI_CLK output and it is 3 KHz instead of 60 MHz as said.
At this point, i am not sure what's happened yet, maybe i missed something, but i check the schematic many times.
if there is nothing can be spotted by NXP support, can i get a replace TWR_SER2 board?
Henry
514 次查看
henrynguyen
i am sorry for your confusion.  it is the measurement problem.  i had the time base too low and it alias to a slower frequency; set the time base to 2.5 GS/s and 1 M points, it shows 60 MHz.
Henry
514 次查看
henrynguyen
I can send back the TWR_SER2 board to NXP.
Henry
