System Watchdog for K70 using MQX
2,697 次查看
sudhanshumehta
I have K70 microcontroller.
using MQX4.2
need to use system watchdog (not software watchdog).
do you have any example for that?
2,576 次查看
sudhanshumehta
5 回复数
2,577 次查看
sudhanshumehta
2,576 次查看
kackle123
Except this is an MQX software watchdog, not an MCU/hardware one.
2,576 次查看
danielchen
Hi Sudhanshu:
Please find the attached validation code for the watchdog module.
In the MQX installation folder, there is a software watchdog demo.
Freescale_MQX_4_2\mqx\examples\watchdog
2,576 次查看
sudhanshumehta
I want system reset watchdog example.
i feel in example section, there is task reset example.
please correct me if i am wrong.
2,576 次查看
sudhanshumehta
This will work on K70 with MQX? Have you tested?
