Sensor Fusion Version
931 次查看
a8Chcx
Contributor V
I used Fusing Version 5.0 and Version 7.0(KDS for K66F was downloaded on Sept. 2019) several years ago.
Now, I am going to build another 9-axes board based on K66F. I want to know if version 7.0 still good to go or there is newer version to use?
Can you send the link to use fusion version because the original forum for fusion is gone?
Christie
909 次查看
EdwinHz
If you downloaded it at Sept, 2019, you should already have the latest version.
Also, you are good to go, since there aren’t any major differences between 7.0 and 7.2.
923 次查看
EdwinHz
Hi @a8Chcx,
Release 7.2 is the latest version. You can find it by clicking on the following link: https://www.nxp.com/design/sensor-developer-resources/nxp-sensor-fusion:XTRSICSNSTLBOXX
BR,
Edwin.
922 次查看
a8Chcx
Contributor V
Thank you, Edwin.
Can you tell me when 7.2 is released?
I downloaded at Sept, 2019 and should be which version? Where to check in file?
Is there any big change compare to V7.0?
Christie
910 次查看
EdwinHz
