[Seek Help] MKL02Z32VFM4 :Why voltage is only 0.4V and more ?
已解决
跳至解决方案
565 次查看
thoomanwang
Contributor V
See schematics, after the plate using Jlink debugging , but found the target voltage is only 0.4V much that I do wrong ?
Battery Voltage : 3.1V
Jlink is intact , use other boards tested.
标签 (1)
标记 (2)
1 解答
481 次查看
thoomanwang
Contributor V
Problem solving, is the power supply pin Jlink caused by poor contact。
在原帖中查看解决方案
1 回复
482 次查看
thoomanwang
Contributor V
