Schematics to implement power sequencing of MK70FN1M0VMJ12
puspamnayak
Greetings for the day !!!
I am using MK70FN1M0VMJ12 in my project so request you to provide schematics for reference to implement Power-Up and Power-Down sequence in my design.
As per page no. 27 of datasheet I need to follow the power sequencing in my design. I have referred  Tower board schematics but not getting the power section where this power sequencing is implemented
Kindly help me regarding this
Thanks and Regards,
Puspam Nayak
chris_brown
Hi Puspam,
The power sequencing on the tower board is guaranteed by sourcing the VDD, VDD_int, and VDDA power pins from the same electrical node (and therefore, the same source).  VDD_DDR is sourced from a power regulator downstream of the P3V3 source (which powers the other domains).  So we rely on the cascaded power supply to guarantee that VDD_DDR is powered after the other supplies.  Does this make sense?
Hope this helps,
Chris
