SREC Decompilation
SREC Decompilation
5,952 次查看
jennifervolk
Hi, We're new to Kinetis and Motorola S-Record files and are working with FOTA for software updates. Our FOTA tool uses srec files generated through the KDS Cross ARM GNU Create Flash Image option. I just wanted to ask whether we'll be able to decompile our srec file into its original .c files once we compile it?
标签 (2)
4,319 次查看
BlackNight
I'm not sure if I understand your question? But the S-Records only contain the code and constant data (see S-Record, Intel Hex and Binary Files | MCU on Eclipse ), so all what you would get from a reverse engineering standpoint is an array of hexadecimal values. If you now the memory map, you can transform this with a disassembler into assembly code with no symbol/variable information: you only will see absolute addresses.
You will not get to the level of C code.
I hope this helps,
Erich
4,320 次查看
BlackNight
I hope this helps,
Erich
