Any example available of a SPI driver implemented in interrupt mode with Kinetis KL o K?
解決済! 解決策の投稿を見る。
Hi Giulio,
I am attaching the files for SPI drivers on interrupt basis on K10 controller.
Hope this helps you.
Nasreen
Thank you Nasreen Shaikh,
the source code you attached has been useful to my development.
Best Regards
G.
Hi Giulio,
There is an example included with CW 10.4, that shows SPI's use with PE. You can find it on this path and its available for several boards: \Freescale\CW MCU v10.4\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis
I hope this helps.
Alberto
Hi Nasreen,
thanks for the code!
May you can help me to understand:
Do I have to set CS manually with PUSHR(buffer | SPI_PUSHR_PCS_MASK) and EOQ?
Raphael
