SDK that support KSZ8041NL for K64
797 次查看
fshah30
Please let me know how I can utilize the SDK from FRDM-K64 board. I am using KSZ8041 PHY on the prototype and want to convert the driver of KSZ8081 which is available in SDK for FRDM-K64. I try to use the same driver but it shows Initialization is fail!!....
775 次查看
EdwinHz
Hi @fshah30,
As you mention, we only provide SDK support for the KSZ8081. Since it is a third party phy, I’m not able to point out any differences that stand out between this and the KSZ8041, so the only viable solution would be to look into both datasheets for these differences and modifying the code accordingly.
Sorry for the inconvenience this may cause.
BR,
Edwin.
768 次查看
fshah30
Thank you
