Hi christhomas
The serial resistance affects the timing of charge the internal capacitor and so the timing of measuring the voltage, the user should assure that this resistance is inside the parameters of the datasheet.
Regarding the reference Voltage, they should be as stable and as high as possible within spec so any noise here could affect your measurements. VREFH means larger ADC code widths.
I recommend you the following Document:
https://www.nxp.com/docs/en/application-note/AN12217.pdf
TIC
- If this post answers your question, please click the "Mark Correct" button. Thank you
