Role of NFC clock of MK70FN1M0VMJ12 in accessing NAND FLASH
955件の閲覧回数
puspamnayak
Dear Members,
I am very eager to know how NFC clock is playing role in accessing data from Parallel NAND FLASH as I am not able to see or find  any NFC clock pin at MK70FN1M0VMJ12.
So wanted to know that without NFC clock pin how handshaking is happening between of MK70FN1M0VMJ12 and Parallel NAND Flash or NFC is using BUS CLOCK.
While Interfacing NFC to Parallel NAND Flash shall I consider NFC CLOCK or BUS CLOCK. Please let me know
Request you to give some more details on this.
Kindly reply at earliest
Puspam Nayak
タグ(1)
825件の閲覧回数
Rick_Li
Hi Puspam Nayak,
while interfacing NFC to NAND Flash, there is no need to consider NFC clock or BUS clock.
as is said in the reference manual of K70, what you need to consider is to configure the NFC clock fast enough (usually >33Mhz) according to the data sheet of flash device.
the communication with NAND flash is asynchronous communication, there is no much requirement on frequency range of NFC.
hope it helps!
